Author Topic: Load capacitors for crystal  (Read 431 times)
Online Jonathon_DoranTopic starter
« on: June 28, 2024, 05:37:53 pm »
I am double-checking some values on a design before I route it, and came across an oddball.  I am trying to use a 16MHz crystal, and JLCPCB has one in its basic parts list!  Great.  But then I get the datasheet and look up the load capacitance...
This is a YXC part, and they list the load capacitance as "10pF, 20pF, or specify".
I just want this thing to start up.   I'm not sure what to make of this.
Any recommendations?
Offline Ice-Tea
    • Freelance Hardware Engineer
Re: Load capacitors for crystal
« Reply #1 on: June 28, 2024, 05:50:28 pm »
Is it not specified in the part number?
« Reply #2 on: June 28, 2024, 06:14:18 pm »
I have no clue, to be honest.  The manufacturer's part number and their datasheet do not match.
This is the part that JLCPCB lists:   X322516MLB4SI
The description is:
16MHz Surface mount crystal oscillator 9pF ±10ppm ±20ppm SMD3225-4P Crystals ROHS
I assume the 9pF is the stray capacitance.  Maybe I have that wrong.
They list the manufacturer as YXC.  The link to a datasheet is for a YXC part, but that datasheet names it YSX321SL.
Offline Ice-Tea
« Reply #3 on: June 28, 2024, 06:32:38 pm »
So, yes, it's part of the PN. Too bad no decoding is provided  :-DD
https://www.yxcxtal.com/product/ysx321sl.html
Offline edavid
« Reply #4 on: June 28, 2024, 06:35:30 pm »
The crystal will always start up.  The load capacitance just determines the frequency.  To get the specified frequency accuracy, you need to use the specified load capacitance.  If you aren't building a clock, don't worry about it too much.
Offline Gyro
« Reply #5 on: June 28, 2024, 06:44:50 pm »
The description is:
That sounds like the load capacitance (I can't open the link that Ice-Tea provided). In an ideal world, that would need a pair of 18pF capacitors. In practice you need to subtract the stray capacitance of the PCB traces and IC, so you're more likely to end up with something like 2 x 12pF.  As edavid says, the absolute value will affect frequency accuracy.
Best Regards, Chris
« Reply #6 on: June 28, 2024, 07:39:02 pm »
Thanks for the link.  The datasheet does not discuss the part numbers.  But even then... "S"?  Well, the part that I am looking at has "L"...  small/large?  Are they trying to tell me to use 20pF loads?
The 9pF value does not appear in the datasheet at all!  And stray capacitance is not shown.  They do list "shunt" capacitance (which I read is the capacitance of the plates).   Why would I care about the shunt capacitance?
Timing is rather important since I want to try to drive some programmable LEDs which rely on timing to control them.  The width of pulses indicate a 0/1.
Maybe the lesson to be learned is to pick a part that has a datasheet that makes sense and not try to save $$$ with a basic JLCPCB part.
Offline TimFox
« Reply #7 on: June 28, 2024, 07:49:33 pm »
For crystals, "shunt" capacitance normally means the required total external capacitance (stray plus on-purpose) in parallel with the crystal terminals to oscillate at the calibrated frequency.
If you want to tweak the frequency, you can use an appropriate (trimmer) variable capacitor.
Crystals can be operated in series-resonant or parallel-resonant mode (different oscillator circuits):  shunt capacitance is specified for parallel-resonant mode operation.
The following users thanked this post: Jonathon_Doran
Offline edavid
« Reply #8 on: June 28, 2024, 10:08:26 pm »
Not really.  No matter what capacitance you use, you can't pull the crystal far enough that the LEDs wouldn't work.  As I said, don't worry about it.  (I would put in capacitor pads, but leave them unpopulated.)
« Last Edit: June 28, 2024, 10:24:58 pm by edavid »
« Reply #9 on: June 29, 2024, 01:34:20 am »
Thanks.  Not populating the capacitors sounds like not trying.  I think 18pF caps will get the job done.
Offline Rabbitoose
  • Country: cn
« Reply #10 on: June 29, 2024, 09:31:19 pm »
I also noticed this for a time. I guess 9pF is mostly like the load capacitance value and I always use it to calculate the proper capacitor value. I used a agilent 53131A to measure the accuracy and the results were ok.
As of why it's not appearing in the datasheet, I believe it's because YXC is lazy on writing a detailed datasheet and just use a simple single version of datasheet for different frequency products of the same series, which have different load capacitances. They might provide the load capacitance value in another way together with the purchase order, and LCSC wrote it on the product page.
As I mentioned, it's a guess, I have no solid proof. But there are many unprofessional practices like this in many companies, which I hated very much as a Chinese.
