xavier60 and 8 Guests are viewing this topic.
What should I do now ? Is ringing normal ?Please have a look at the previous post and tell me what you think ...
Edit: probes should usually be set to X10.
hope there will be a schematic+pcb artwork released for this when sorted!.
Please find attached the kicad files.
So if I use 5 transistors, should I also use 0.1R emitter sharing resistors instead of 0.22R resistors ?
The maximum current is 5A (I mean the output current of the PSU).I used 5 transistors, so the current through each should be 1A. So 1A*0.22R = 0.22V across each resistor.
Would you be so kind as to identify the components labeled R34 & R37 100mA with part number and mfg ? Thanks
