Author Topic: LM324 Power Supply with variable voltage and current  (Read 190534 times)
Offline mike_mikeTopic starter
Re: LM324 Power Supply with variable voltage and current
« Reply #1150 on: December 18, 2023, 03:39:58 am »
Yes it is more ringing at the drain of the mosfet. The mosfet is a 2SK1257.
Blue channel = output of NE555
Yellow channel = drain of the mosfet.
This means that the wiring damp the oscillation at the Drain of the mosfet ?
« Last Edit: December 18, 2023, 03:32:54 pm by mike_mike »
« Reply #1151 on: December 18, 2023, 05:18:46 pm »
What should I do now ?
Is ringing normal ?
Please have a look at the previous post and tell me what you think ...
Offline iMo
  • Country: vc
« Reply #1152 on: December 18, 2023, 05:46:34 pm »
There is an npn transistor between the power mosfet and the 555, afaik..
Also the frequency of the ringing is aprox 15MHz.. That might come from leads inductance..
« Last Edit: December 18, 2023, 05:54:10 pm by iMo »
Offline xavier60
« Reply #1153 on: December 18, 2023, 06:48:45 pm »
Is ringing normal ?
That ringing is normal and external to the PSU.
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
The following users thanked this post: mike_mike
Offline xavier60
« Reply #1154 on: December 19, 2023, 06:19:23 am »
The stimulus for the ringing could be actually originating from the NE555 itself. Try putting a resistor in series with the CH2 probe tip, between 1K and 10K.
« Reply #1155 on: December 19, 2023, 03:47:48 pm »
Please find attached the screenshot when I used a 4.7k resistor between the pin 3 of NE555 and the tip of CH2 probe (blue trace).
The yellow trace is the output of the PSU, Vout=2.5V, Rload = 10R.
It looks like the ringing almost disappeared.
« Last Edit: December 19, 2023, 04:24:59 pm by mike_mike »
Offline xavier60
« Reply #1156 on: December 19, 2023, 08:19:10 pm »
That's much cleaner.
Edit: probes should usually be set to X10.
« Last Edit: December 19, 2023, 08:41:58 pm by xavier60 »
« Reply #1157 on: December 19, 2023, 09:04:01 pm »
Yes, they were set to X10.
Offline p.larner
« Reply #1158 on: December 20, 2023, 11:02:25 pm »
hope there will be a schematic+pcb artwork released for this when sorted!.
Offline xavier60
« Reply #1159 on: December 20, 2023, 11:47:20 pm »
My build of the design has been working well for years.
https://www.eevblog.com/forum/beginners/lm324-power-supply-with-variable-voltage-and-current/msg3582664/#msg3582664
My PCB files are Protel 98. I suspect that mike_mike's is Kicad which I'm sure he will share.
« Reply #1160 on: December 21, 2023, 03:22:12 am »
Please find attached the kicad files.
The following users thanked this post: the Chris, p.larner
Offline xavier60
« Reply #1161 on: December 24, 2023, 10:12:50 pm »
You should also include the output stage in the schematic. Use the same reference numbers as used in mine.
Offline p.larner
« Reply #1162 on: December 25, 2023, 03:57:09 am »
thank you for the download merry xmas.
« Reply #1163 on: December 25, 2023, 08:32:59 pm »
And the transformer tap switcher files.
Offline xavier60
« Reply #1164 on: December 26, 2023, 01:55:22 am »
A word about the Emitter sharing resistors, R14 and R15. Although I have used 50mΩ, 100mΩ resistors should be used unless Q3 qnd Q4 are very well matched as mine happen to be.
« Reply #1165 on: December 26, 2023, 05:40:28 am »
So if I use 5 transistors, should I also use 0.1R emitter sharing resistors instead of 0.22R resistors ?
« Last Edit: December 26, 2023, 06:12:28 am by mike_mike »
Offline xavier60
« Reply #1166 on: December 26, 2023, 06:20:11 am »
No.
Using that many transistors is usually for SOA reasons to get the current per transistor down. So, voltage loss becomes less of a concern.
The trade-off is, good sharing against voltage loss.
You can calculate the voltage loss, also measure the voltage across each resistor to check the sharing.
« Last Edit: December 26, 2023, 06:22:58 am by xavier60 »
Offline xavier60
« Reply #1167 on: December 26, 2023, 06:28:27 am »
What is your maximum current? I should have asked.
« Reply #1168 on: December 26, 2023, 06:41:22 am »
The maximum current is 5A (I mean the output current of the PSU).
I used 5 transistors, so the current through each should be 1A. So 1A*0.22R = 0.22V across each resistor.
Offline xavier60
« Reply #1169 on: December 26, 2023, 06:47:00 am »
Not a problem, leave it as is.
Offline dennislewis
« Reply #1170 on: February 20, 2024, 01:47:08 pm »
I want to say thanks for the time and effort put into this project. The sharing of ideas was helpful.
mike_mike the pcb looks nice.
Did any others build this and/or have comments on the project ?
Offline dennislewis
« Reply #1171 on: February 25, 2024, 12:47:35 am »
Would you be so kind as to identify the components labeled R34 & R37 100mA with part number and mfg ?
Thanks
Offline xavier60
« Reply #1172 on: February 25, 2024, 12:58:01 am »
Thanks
They are a 100mA Polyswitch such as RXEF010.
Added: A blue LED should work fine in place of the white LED.
« Last Edit: February 25, 2024, 07:44:42 am by xavier60 »
« Reply #1173 on: April 05, 2024, 03:15:04 am »
I tested again with another scope (unit UTD2052CEX+) and the output of the power supply looks like this now (see the attached screenshots).
It is normally to look like this or there are some problems ?
Offline xavier60
« Reply #1174 on: April 05, 2024, 03:30:25 am »
The effect might be caused by long wires. Is the probe connected directly to the PSU's output terminals?
