I removed the pot, I used R6=27K, R8=12K, I connected a 100k resistor between the pin 5 and the right side of the shunt resistor.
The voltages on the pin 5 and 6 are as follows:
1. With SlowCC active:
pin 5=2.53V
pin 6=3.67V
2. With 2.5A load without SlowCC active:
pin 5=5.55V
pin 6=3.74V
3. Without load:
pin 5=5.08V
pin 6=3.31V
Regarding what you said in the previous post, the 100k resistor can be connected on any of the GND (left or right of the 0.22 R shunt), but if connected to the right side of the shunt, then it will consume current through the shunt, but it can be connected on either one of the GND's ?
