What is the reason for the disturbance in DS0099.jpg and DS0111.jpg, 2.5ms after the current spike?
Quote from: xavier60 on October 12, 2019, 11:31:42 amWhat is the reason for the disturbance in DS0099.jpg and DS0111.jpg, 2.5ms after the current spike?I searched on the output of the NE555 and in the C of the BC337 (the NPN transistor from the PSU Shorter) and I did not found that disturbance. So it could be from other source. I don't know which source.
Can you please explain what is the meaning of "milder overloads" and the "current settles" ? I guess milder overloads mean overloads less than 3A, for examle 1.5A. So I need to set the maximum output voltage to 1A, then I need to apply a 1.5A load and see how the current settles ?
I already installed a 1k/5W resistor on the output. This was installed from the last built configuration of the power supply...
