My MOD schematics works fine in simulation with the PSU_Shorter Vout=1V-30.6V based on CV pot's position.
Based on the activity the voltages at opamp's outputs are from 0.68V to 10.5V, and the Q1's base voltage is from 0.8 to 1.6V, the Q1's collector current is 21uA-300uA.
If I were you, I would start with LTspice. You have done a lot of great work by building various types of PSUs, the next step could be the refining of the "design phase" - here the LTspice is the right tool to use.
