Author Topic: LM324 Power Supply with variable voltage and current  (Read 194404 times)
0 Members and 12 Guests are viewing this topic.
Online xavier60
Re: LM324 Power Supply with variable voltage and current
« Reply #1000 on: March 30, 2022, 04:17:48 pm »
How have you wired the switch poles?
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
Offline mike_mikeTopic starter
« Reply #1001 on: March 30, 2022, 04:21:22 pm »
The first pole is wired like in the first schematic, and the second pole is connected as a switch that is connecting and disconnecting the wire between the 5V reference and the pot's pins (reply #997 schematic)
Online xavier60
« Reply #1002 on: March 30, 2022, 04:25:05 pm »
Is one pole on while the other pole is off?
« Reply #1003 on: March 30, 2022, 04:26:21 pm »
Both poles are on at the same time.
Online xavier60
« Reply #1004 on: March 30, 2022, 04:30:11 pm »
That's right. It should be working.
« Reply #1005 on: March 30, 2022, 04:32:28 pm »
I am always hearing the relay clicking when the psu is going from off to on state.
For example: Vout=32V, I out=3A, I am turning off the psu then I turn it on and while I am pressing the switch I hear the relay clicking. Even if the relay was initially on.
« Last Edit: March 30, 2022, 04:34:22 pm by mike_mike »
Online xavier60
« Reply #1006 on: March 30, 2022, 04:38:35 pm »
Put the switch in the position where there is 5V on the pots and the PSU has output.
Then check that the pole in the tap change circuit is on.
Online xavier60
« Reply #1007 on: March 30, 2022, 04:54:22 pm »
Maybe there is a big problem with the idea if the pole for the reference turns off before the other pole.
Online xavier60
« Reply #1008 on: March 30, 2022, 05:05:24 pm »
With the way it originally was, the switch contacts timing avoided glitches. The pole in the tap changer opened before the pole on the Shutdown closed. This prevented the tap changer responding to the drop of PSU output voltage.
« Reply #1009 on: March 30, 2022, 05:26:02 pm »
I don't think that I will find a perfect switch.
If I will use the power supply with the actual relay clicking, it could be a problem ? For example will the relay be damaged ?
« Reply #1010 on: March 30, 2022, 06:14:34 pm »
No, it's fine the way it is. It was a suggested improvement.
The switch needs to be wired so that both poles are on at the same time.
Ok, then I would like to leave the psu as it is.
Online xavier60
« Reply #1011 on: March 30, 2022, 09:21:08 pm »
I fell asleep here. Yes, it will have to stay the way it is. I can't think of a simple solution for the relay clicking which we were wanting to avoid in the first place  in the design of the tap change circuit.
Online xavier60
« Reply #1012 on: March 30, 2022, 09:43:12 pm »
Actually I have just thought of something. Increasing C2 in the tap change circuit will increase the delay to change time.
There still could be unforeseeable complications.  So experiment only if you have plenty of spare time to use.
« Reply #1013 on: March 31, 2022, 08:35:54 am »
I will leave the psu as it was before the last suggested improvement.
Offline not1xor1
« Reply #1014 on: March 31, 2022, 12:10:34 pm »
I tried to simulate with LTspice that schematic with TLC072 (PS4s03.jpg - is that the last schematic?) but it oscillates at about 1-2kHz. The bode plot is scary...  :scared:
If anybody would like to check I can post a zip with the models I used.
Online xavier60
« Reply #1015 on: March 31, 2022, 12:45:06 pm »
The latest is PS42 012.png on https://www.eevblog.com/forum/beginners/lm324-power-supply-with-variable-voltage-and-current/msg3582664/#msg3582664
It's not significantly different.
The CV loop should oscillate over 100Khz with no compensation.
« Reply #1016 on: March 31, 2022, 04:34:56 pm »
Is there anything that I should do if the psu oscillates ? I checked the psu, some time ago, when I finished the latest schematic, and it seems that it didn't oscillate (at that moment).
What else should I do ? is there anything that I should modify or test ?
« Last Edit: March 31, 2022, 04:39:56 pm by mike_mike »
Online xavier60
« Reply #1017 on: March 31, 2022, 09:05:22 pm »
You could test it again, it will be fine.  I use the same design in my main bench PSU and have not seen oscillation problems in almost 3 years.
There is very likely a mistake in the simulation.
The following users thanked this post: mike_mike
Offline Kleinstein
« Reply #1018 on: March 31, 2022, 09:40:35 pm »
The ESR of C2 could make a difference for the stability and help the voltage loop.
There are other parts that are not modeled perfectly.  One such part is inductance of the shunt, that can have an effect, though often also to make a real world circuit oscillate if the simulation is stable.
Online xavier60
« Reply #1019 on: April 01, 2022, 12:34:02 am »
A sure way to make it oscillate is to apply type 1 compensation(C + no R) and an extremely low ESR cap across the output.
This is commonly known to apply in general to current sourcing designs such as Harrison topology and LDO regulators.
« Last Edit: April 17, 2022, 10:26:50 am by xavier60 »
Offline not1xor1
« Reply #1020 on: April 01, 2022, 09:10:04 am »
I downloaded the TLC072 model from TI and the TIP35 one from onsemi.
The bodeplot of a simple circuit with just TLC072 matches the datasheet one, so the library should be OK.
Unfortunately the test (control voltage only) yields quite wild results. (See image below)
I'm including the simulation in order to allow to check what is wrong with that.
Please let me know what is wrong ... or if it is just a simulation problem.
thanks
Online xavier60
« Reply #1021 on: April 01, 2022, 11:50:24 am »
Your signal injection point isn't in the usual spot. It should be between the + output and R16.
I have just been doing some testing on my actual PSU. Ill report back when I make sense of it all.
« Last Edit: April 01, 2022, 08:35:07 pm by xavier60 »
Online xavier60
« Reply #1022 on: April 01, 2022, 12:00:12 pm »
Ok, with a 1A load, loop gain is 0dB at 115KHz. Allowing for the phase inversion, the output lags the waveform at the top of R16 by 120°.
So I guess the stability phase margin is 60°.
« Reply #1023 on: April 02, 2022, 10:29:34 am »
@xavier60 Did you made any other tests with the psu ? If yes, then could you please share with us the conclusions ?
Online xavier60
« Reply #1024 on: April 02, 2022, 10:39:07 am »
No, just the stability phase margin test. 115Khz isn't all that fast but the stability is the most important thing which is proven to be  very good.
