A snubber is a more suitable remedy
Doesn't really solve the problem, does it?
From your PDF:
· Reduce or eliminate voltage or current spikes
· Limit dI/dt or dV/dt
· Shape the load line to keep it within the safe operating area (SOA)
· Transfer power dissipation from the switch to a resistor or a useful load
· Reduce total losses due to switching
· Reduce EMI by damping voltage and current ringing
I see nothing about dissipating the energy stored in the inductor. Try again.
