Hey,
no, I meant that I want to connect the load (close the switch) only after the supercap has reached at least 4.5V. If I connect the load before I might not have enough power to charge the supercapacitor AND power the load at the same time. So, only after the supercap is charged enough I can discharge the energy on the load. Similarly, while discharging, if I go down to 2V I want to open the switch (disconnect the load) because there is not enough voltage to supply.
