I have made a charging circuit using the famous MCP73831T-2ACI/OT.
I does work (it seems) , but stops charging once it hits 3.6v. When the battery was new, I would start off at 3.8v. Is this normal, or should it charge it up again to 3.7/3.8?
Im using a 2k resistor, so I should charge 500mAH (i think).
Any advice would be appreciated
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Thanks
