Author Topic: Using both switch-mode and linear supplies in one application.  (Read 1216 times)
Offline medical-nerdTopic starter
  • What's that coming over the hill?
Hiya
Are there any problems that I should be aware of if I use both switch-mode and linear power supplies for one application or one board?
I have a low noise switch mode supply for +/-12V 2A +/-5v 8A but a few items need in addition +24V or -24V which will be up to 1.5A for all of them - for which I plan to use a simple linear supply not supplied from the existing switch-mode.
I'm using salvaged microwave/rf modules from the 80's that need the multiple voltages and don't want to release the magic smoke.
Do I just connect all the 0V of the supplies? Can I assume that they will be at the same potential?
Cheers
Steve
'better to burn out than fade away'
Re: Using both switch-mode and linear supplies in one application.
« Reply #1 on: April 19, 2017, 12:53:17 pm »
Many thanks evb149 for your comprehensive reply.
They are a mixture of circuit blocks on pcbs and separate shielded boxed modules.
I like the idea of using multiple regulators to reduce the current in each - I certainly have enough to do this and will.
I will work through your links this evening.
Cheers
Steve
