Author Topic: Programmable boost converter  (Read 1093 times)
Offline tridentsxTopic starter
« on: November 22, 2015, 09:01:37 am »
I am trying to find a dc/dc boost converter that takes 5V IN and supplies 5V to 25 V. The converter should have an MCU serial interface I2C/SPI etc ... where the output voltage is programmable and the IC provides a constant voltage at a current draw up to 50 ma. Wouldn't mind if the current draw was monitored with programmable shutoff and readout available via the serial interface. The current monitoring is not .a must but would be good to have
Is there anything like that out there ?
