Sir, I do not understand your language. My question is very clear. There is an RC car that works at 7.5 volts. What is important here is not how many volts the RC car is, but how many volts the battery is charged. It needs 7.5 volts, the battery itself, this question is a simple problem, there is no need to discuss it, after all, it charges the battery, I took the adapter back. This is the adapter itself in the same picture
Some batteries can be charged with a fixed voltage (lead or lithium), others with a constant current (NiCd, Nimh), but always there is some "protocol of charge" (start chaging with x current or voltage, later continue in another mode, cut current when something occurs..) that charges better the battery (faster and with less probabilty of damage the battery). So normally no battery is charged connecting directly to a power supply, but through a special circuit, the charger. Many people call "charger" to any adapter, but they are not the same.
There is no battery that can be charged with 7.5 V, if you use lead, you need 2.4 volt per cell, if you use liion, 4.2, so 7.5 V is not adecuate. Also, be very carefull with liion,
they do not tolerate any overvoltage, the voltage has to be very precise. Other batteries normally fail without too much viloence, but liion explode easily.
