so does that digikey offer come sorted by chapter at least? I'm thinking of buying the book but I dont want to spend $300 up front on all the parts, I'd rather buy the parts as Im doing the chapters.
I wouldn't think so. I would expect to receive identical components in a clear plastic envelope with a label. Just like the other parts I receive from DigiKey. The key to this is that there isn't a single part number for the kit but rather a long shopping list added to the cart. I would expect to see as many envelopes as lines in the shopping cart.
You would need to look ahead to order parts. Maybe do 3 or 4 chapters at a time. If you don't, shipping and time lag will become an issue.
Also, some of the more expensive parts may be for experiments you intend to pencil whip. Some of the digital examples are trivial and might just be glossed over. Especially if they use parts that only apply to that particular experiment.
It also makes sense to buy resistor, capacitor and transistor kits rather than individual values/types.
https://www.jameco.com/z/00081832-540-Piece-1-4-Watt-5-Carbon-Film-Resistor-Component-Kit_81832.htmlJameco has kits for multiple wattage resistor, several types of capacitors, transistors and so on. I like these kits because they come in a storage box. I refill individual values with 100 pc lots from DigiKey. Obviously, there are other ways to build up stock.
For example, you can overbuy when you order from DigiKey.
You really can't be in the game without at least some stock-on-hand.
