Hello.
I have been working on an audio switch, using a 4053, and have breadboarded my design so far. One of the problems I am having is that none of the low frequency is passing through the IC.
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
I have attached a simplified version below. Basically. Line level comes in, and a high pass filter filters out the existing DC. I then add in my VBias, and run it through the switch. On the other side I have another high pass filter on the other side.
What I think my problem is, is that I have a problem with my math. The formula f=1/(2piCR) should calculate the cutoff frequency, which I know I want to keep much lower than 20hz.
I have two theory's of what is wrong.
a) because I have two resistors on each high pass filter, is 1/R=1/R1+1/R2?, or
b) Is it actually 1/R = 1/R1+1/R2+1/R3+1/R4, or
c) Am I completely wrong.
I know the practical answer is just increase the capacitors and resistor values until it sounds good, but I would like to understand my error.
