Author Topic: lcd, C and pic  (Read 7728 times)
Offline ZedyTopic starter
lcd, C and pic
« on: August 22, 2010, 04:06:47 pm »
Hi, I am working right now on my lcd project, and I have some problem with lcd initialization:
After this peace of code, LCD just don't work, but if I change LCD_EN to portB pin (in softwere and hardwere) all works fine. Any help would be appreciated.
(pic microcontroller: PIC16F677, LCD module 8x2)
#include <htc.h>
#define _XTAL_FREQ 4000000
#define lcd_port    PORTC
#define LCD_EN      RC4
#define LCD_RS      RC5
__CONFIG(INTIO & WDTDIS & PWRTDIS & MCLREN & UNPROTECT & BORDIS & IESODIS & FCMDIS);
void init(void)
// port directions: 1=input, 0=output
TRISA = 0b00000000;
TRISB = 0b00000000;
TRISC = 0b00000000;
void main(void)
init();
lcd_port = 0x00;
__delay_ms(50);
                lcd_port = 0x03;
LCD_EN = 1;
LCD_EN = 0;
__delay_ms(10);
       lcd_port = 0x02;   //Function set
LCD_EN = 1;
LCD_EN = 0;
                lcd_port = 0x08;
LCD_EN = 1;
LCD_EN = 0;
__delay_ms(10);
LCD_EN = 1;
LCD_EN = 0;
                lcd_port = 0x08;
LCD_EN = 1;
LCD_EN = 0;
__delay_ms(10);
lcd_port = 0x00;   //Display on/off
LCD_EN = 1;
LCD_EN = 0;
                lcd_port = 0x08;
LCD_EN = 1;
LCD_EN = 0;
__delay_ms(10);
lcd_port = 0x00;   //Display Clear
LCD_EN = 1;
LCD_EN = 0;
                lcd_port = 0x01;
LCD_EN = 1;
LCD_EN = 0;
__delay_ms(10);
lcd_port = 0x00; //Entry Mode set
LCD_EN = 1;
LCD_EN = 0;
lcd_port = 0x06;
LCD_EN = 1;
LCD_EN = 0;
__delay_ms(10);
     while(1)
What is going on?   ???  :)
« Last Edit: August 22, 2010, 05:16:55 pm by Zedy »
alm
  • Guest
Re: lcd, C and pic
« Reply #1 on: August 22, 2010, 04:39:09 pm »
You should use code tags (button with hash/pound/number sign) to make the C code more readable. I'm not a PIC person, but is there anything else on PORTC that might conflict, like programming pins, reset pin or crystal pins? Check the datasheet for your PIC.
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: lcd, C and pic
« Reply #2 on: August 22, 2010, 05:07:25 pm »
have you setup your registers correctly
Re: lcd, C and pic
« Reply #3 on: August 22, 2010, 05:42:41 pm »
There is nothing else, just pic and LCD module, the only thing about PORTC, some of the pins are part of compartors and  analog pins, but I use them only like output pins.
I think so, but I also have trayed to disable other functions of the pins in softwere. Nothing changes, it just don't work if lcd enable pin is connected to the same port.
« Last Edit: August 22, 2010, 05:44:26 pm by Zedy »
Offline migsantiago
    • MigSantiago's Web Site
Re: lcd, C and pic
« Reply #4 on: August 22, 2010, 07:26:04 pm »
Hello Zedy
You should tell the HiTech compiler which pic you're using...
#include <htc.h> // Required to interface with delay routines
#include <pic12f683.h> //modify this with your pic
And be careful when using lcd_port, because you're actually modifying the 8 bits of the port at the same time... including RC4 and RC5, which should not be changed.
I'd recommend using that LCD on a 4bit mode and whenever you want to send a 4 bit command or data, be sure not to modify the other RCx pins.
In order to do that you'll have to use AND, OR or XOR masks.
Ohh and there is a pre-built LCD library with Hitech, just search for it in the installation paths.
Re: lcd, C and pic
« Reply #5 on: August 22, 2010, 08:58:58 pm »
Hello Zedy
I have 9.70 HiTech compiler version.
Thanks! I have found LCD library, and with little code modification it works very nice!
Offline migsantiago
Re: lcd, C and pic
« Reply #6 on: August 22, 2010, 10:19:32 pm »
No, it doesn't matter what version you're using, it's always recommended to include the header file for the specific PIC you are using...
Congratulations on your first LCD project!  ;D
Offline Simon
  • Global Moderator
Re: lcd, C and pic
« Reply #7 on: August 23, 2010, 06:47:15 am »
yea I'm hoping to do something with LCD's soon just got to get one project up and running
Re: lcd, C and pic
« Reply #8 on: August 23, 2010, 04:55:13 pm »
Thanks!  :)  I have included header for my pic, so now all seems to be right.  :)
It was really painful process for me, I spant almost month just trying understand how lcd module works  ;D
« Last Edit: August 23, 2010, 05:00:03 pm by Zedy »
Offline FreeThinker
  • Truth through Thought
Re: lcd, C and pic
« Reply #9 on: September 09, 2010, 06:18:10 pm »
Hi, Have a read of this
http://www.epemag.wimborne.co.uk/resources.htm
The LCD pdf's are a Good read. Hope they help
Machines were mice and Men were lions once upon a time, but now that it's the opposite it's twice upon a time.
MOONDOG
Re: lcd, C and pic
« Reply #10 on: September 09, 2010, 08:06:26 pm »
The links to LCD pdf's are broken.
Offline djsb
Hertfordshire, UK
University Electronics Technician, London, PIC16/18, CCS PCM C, Arduino UNO, NANO,ESP32, KiCad V8+, Altium Designer 21.4.1, Alibre Design Expert 28 & FreeCAD beginner. LPKF S103,S62 PCB router Operator, Electronics instructor. Credited KiCad French to English translator
