'Loudspeaker' is usually just one word.Some more you could consider adding include variable capacitor, variable inductor, FET, thyristor, SCR, Zener diode, Schottky diode, varicap diode, photodiode and aerial/antenna.
I still don't like S2... It should be "SPDT switch" (Single Pole Double Throw)
I still don't like S2... It should be "SPDT switch" (Single Pole Double Throw)"Electrical wires" I'd change to "Unconnected Electrical wires"The LED might be better labeled "Light Emitting Diode (LED)""Relay switch" should be "Relay contact"
Quote from: Kim Christensen on February 14, 2023, 07:06:53 pmI still don't like S2... It should be "SPDT switch" (Single Pole Double Throw)I think "double throw switch" is fine. SPDT is an abbreviation, and abbreviations can be avoided when clarity is desirable.
Component types have a certain background. We teach that in an electrical circuit there are 4 types of components (generators, conductors, loads and control elements).These four types of components must appear on the sheet.
Bulb lamp: incandescent lamp. OkInductor/coil: inductor. OkSwitch: switch SPST. Too much difficultDouble throw switch: switch SPDT. Difficult and not very expressiveNormally open pushbutton: pushbutton NO. I prefer not to use acronyms on the simplest components.Normally closed pushbutton: pushbutton NC.
Headlines:Headings:Generators; voltage sources (apparently you don't consider current here).Electrical receivers: electrical loads or just loads.Control components: electromechanic electromechanical components.Devices:Bulb lamp: incandescent lamp.Inductor/coil: inductor.Switch: switch SPST SPST switch Double throw switch: switch SPDT SPDT switch Normally open pushbutton: pushbutton NO NO pushbutton (better: momentary switch, NO)Normally closed pushbutton: pushbutton NC NC pushbutton (better: momentary switch, NC)Placing potentiometer in the sensors section is unusual, but that's more a matter of taste.
Ideally I'd suggest adding an extra two pins to your op amp symbol, which you can use to show what power rails are used, this becomes important for telling the diffeence between split supplies vs things to run from batteries vs situations where you have a battery but are using yet another voltage level as one of the op amp rails.
Also LDR's aren't so common any more, photofiodes and phototransistors do a lot of the same things but work well for faster varying signals. So I'd add symbols for those.
