hey
hitachi8 . yes . because 50 hours is pretty much all I got for fun ,
hey fenderbender , I'm 16 years old , just 1 year apart
I plan to get locally an old analog scope , just for what Dave has mentioned , the old ones can capture things that the DSO just cant , plus , If I'll have both the DSO and the analog , I'll have 4CH to work with if I'll need to
I received my HP-3610A , great power supply , came calibrated+certificate , the only thing was the knobs , few (6) of them was either not match the pic or slightly tear (the binding posts ... )
apart from that , wow , that's a good one , Question : I set the voltage to X value . and then I loaded it with 0-1A CC , the difference between the set voltage and the voltage under load was exactly 82mV (I tried few voltage setting ,) is it OK for those HP-36XX series power supply ?
now my project is that 1A CC , after that , I'll work on the PS , the whole idea is not to compare with low ripple noise and stuff like this , the supply should be capable to just power on some stuff , the desired values are 15V at 5A X4 ,
now when I thinking on it , can you all post me here ,
(1) . what sort of field you are working at ?
(2) . what are the voltage@current requirement that you very often need/use ?
(3) .whats the number of channels you find yourself "must have"
(4) .how important is the ripple noise for that usage ?
(5) .what is the accuracy(and number of counts[or]> 4 1/2 or 3 1/2 ) needed for the panel meters & the CV set ?
(6) assuming I'd like to have multiple ranges (for each individual CH ) what are the CC & CV valeuse you'll recommend/need for each range ?
(7) what option(s) (besides remote sens ) you "must" have for you're own usage(s) ?
if you've got more questions you'd like to ask / think I should think of , please post them here !
(+++) : if that post need to be in another thread please note me (either here of in PM m I think (?)
thank you in advance ! and I hope that will get me off the un needed specs and focus me straight froward the real target I've aimed for
