thanks , I am already know that , but unfortunately , I am not from there
. and I have got 3 meters too , so with my 950$ limited budget, I think it won't be so smart , but thank you anyway !
How much are you thinking of paying for it? Buying HP/Agilent is usually a BAD idea because they are far overpriced. This particular PSU isn't all that great: 30W is quite pathetic really. I'd recommend going for a GPS-4303 (http://www.tequipment.net/InstekGPS4303.html) if you can.
hey , thank you , but I am not after the power here , what I was looking for is the low ripple high usability and reliability in the long term .
for the higher power project's of mine , in the future , I'll build the 300W power supply I wanted too , ( 4X 0-15V@0-5A , or maybe even 1.25V -2.5-upon the regulation circuit , ) I really think that 0-6V@3A and 0-15V@2A is quiet ideal for circuitry ( op-amps, amplifiers,oscillators , etc etc ... )
for now, I have got "hacked" ATX , I changed the voltage to be about 12.2V@18A full load (It does some high frequency noise from the transformer or maybe the switching element's - IE MOSFET's ><" ) so for 216W power supply (at the 12V terminal only ! ) it's kinda hi power and I can't really see why should I go over my head , I might build some electronic load ; 120W (0-120V@0-10A ) so at 12V@10A or as high as 120V@ 1A I think it should do for me
at the beginning , I had some crazy ideas (such as 0-30V@0-100A power supply ) , but at the time , I realized , that a good idea will be to use some chippie ATX power supplies if needed (rewound the secondary and change few components and values ) ,
look at me , my requirements went that low , from 3KW down to 30W
I figured that if I'll need some 30V@10A supply , I'll go to that page and begin with soldering , here :
http://www.chirio.com/switching_power_supply_atx.htmthank you in advance !
