I'm waiting for a friend to decide what he also wants from TME and then we will place an order.
I think PWs should be fine for the task .Their specs are decent and they are rated specifically for switching psus.
PWs are also much cheaper than Panasonic FCs (not that cost matters for this kind of repair)
Here's what I plan to order:
http://www.tme.eu/gr/details/upw1e102mhd/puknote_-ilektrolut-tit-chamil-antist/nichicon/Would it be a wise choice to replace every electrolytic in that section or just try my luck with these six?
Also,is there any trick to remove the psu shield?!
I've removed the screws but it's somehow stuck in there.
Maybe remove the little pcb in front of it?The one with the soldered leg-pins.
@vulturebetrayer Thanks a lot for these files and for your time iploading them!
@David Hess You've been a great help so far.Thanks!
While the soldering looks factory I think the caps on mine have been changed..
I saw pictures of another 2235 supply and the originals should be mallory brand and 840uf at 12V.
@R005t3r
I think I'll just wait for a replacement to appear.
I don't have a 3d printer or access to one but even if I did I wouldn't bother since ,as you say, it might be more difficult than one would think.
