Author Topic: PreAmp Biasing Trimpot issue?  (Read 2450 times)
Offline lesabbTopic starter
« on: February 29, 2016, 03:59:20 pm »
I am newbie and trying to build the pre-amp section of the Neve 1073. I decided to bread board the BA283AM ONLY as per the attached schematics. I think there is a problem but i can’t seem to find it. The collector voltage on the 2N6248 is 20.6V. Shouldn't it be higher? When I turn the trimpot nothing happens. The Base voltage is ~10.6V and the E is at ~ 10V, which I think is OK but a bit higher than previously reported (~3V). Consequently, the C voltage of Q1 is at ~10.6V (much higher than the reported 3.6V). The transformer is connected to the 24V PSU and to the output of the BA283AM as per the schematics.Any troubleshooting ideas? Thanks
Luc
Offline Seekonk
Re: PreAmp Biasing Trimpot issue?
« Reply #1 on: February 29, 2016, 05:30:36 pm »
I don't see any bias turning Q1 on.
« Reply #2 on: February 29, 2016, 06:04:20 pm »
THis is what the whole thing is like.
Offline Seekonk
« Reply #3 on: February 29, 2016, 08:25:32 pm »
Obviously the output transistor it being turned on much, so the issue is in Q2&3. These should follow .6V drops.  When you get enough voltage 47 ohm, Q1 will stabilize the circuit.
« Reply #4 on: February 29, 2016, 10:02:58 pm »
I don't know if I understand but the Q1 & Q2 Vbe is 0.6V drop
Offline Seekonk
« Reply #5 on: February 29, 2016, 11:32:32 pm »
Q2&3 are a simple darlington.  Problem should be obvious from the voltages.
Offline Andy Watson
« Reply #6 on: February 29, 2016, 11:46:00 pm »
Either the emitter resistor is not 1k2, or the collector resistor is not 68k - or possibly Q2 is dead or wrongly connected. 10V across 1k2 would require a current of 8.3 mA - so either the collector circuit of Q1 is wrong - too low resistance, or the emitter circuit has too much resistance.
« Reply #7 on: March 01, 2016, 12:49:42 am »
Thanks, I forgot that I was using MPSA06, not BC184C! Pinout is the opposite! HOWEVER now when i power up, the 47R smokes! I will go back and re-wire. My 47R is a 2W resistor.
