Hey thanks for the help on this, I did measure it and assume it was something else because it was coming up as a short. The problem is with the IC nearby, the charging battery management IC however as a part of removing that IC, I was concern that I overheated that resistor component. I swap it out just in case.
The unit is actually not thermal imager but a radiation detector FLIR makes. Thanks!
