Author Topic: Will a 2.2KOhm 10W resistor work as a dummy load for DC supply?  (Read 12742 times)
Offline raspberrypiTopic starter
« on: February 17, 2017, 04:16:37 am »
I have a 2.2k 10Watt power resistor and I'm testing a power supply (The 1.25 to 12V one)
Will this work as a load?
What about a 10Ohm 10 watt?
I'm legally blind so sometimes I ask obvious questions, but its because I can't see well.
Offline drussell
  • Hardcore Geek
The following users thanked this post: ebclr
Offline tautech
Re: Will a 2.2KOhm 10W resistor work as a dummy load for DC supply?
« Reply #2 on: February 17, 2017, 05:00:49 am »
A few auto bulbs are good. 6V ones from smaller kickstart bikes, 12V from stop and tail indicators or instrumentation bulbs. eg. a 12V 21W bulb draws ~1.75 A and you can push them to 15V for short periods for a bit more draw.
Offline Brumby
« Reply #3 on: February 17, 2017, 05:30:26 am »
2.2k resistor on 1.25v will pull just under 0.6mA and dissipate around 0.7mW
2.2k resistor on 12v will pull around 5.5mA and dissipate around 65mW
Neither of these are much of a test on a power supply - and a 10W resistor isn't going to get noticeably warm.
10ohm resistor on 1.25v will pull 125mA and dissipate around 156mW
Again, this isn't much of a test.
10ohm resistor on 12v will pull 1.2A and dissipate 14.4W
This IS a better test for the power supply - so long as it is rated to deliver at least 1.2A.  However, it's not much fun for the resistor, since this exceeds its power rating.  If you wanted to do a test at this current for 5 seconds, I wouldn't be too worried - but leaving it for 5 minutes would not be on my list of 'good ideas'.
As suggested above, use Ohm's Law to work out appropriate resistor values and calculate power dissipation to make sure your load can handle it.  (Suggestion - work through the figures from what I have posted above and see if you get the same answers.)
Automotive bulbs are not a bad choice either - but just remember to work out the current from the voltage and power figures.  Measuring the filament resistance when it is cold won't give you the right figure - because the filament resistance increases as it heats up.
AND - as with any testing procedure - make sure you are performing your tests within the specifications of the device under test (DUT) .... unless you are testing to failure.
« Last Edit: February 17, 2017, 05:35:08 am by Brumby »
« Reply #4 on: February 17, 2017, 07:14:49 am »
Yes I did use ohms law came up with the same values in the third post. My question should have been: Do dummy loads need to be running your power supply at their limit to get consistent results? Such as the 10 ohm draws about 1 amp at 12 volts. Transformer is rated at ~15watts (15VACx1100ma).
Offline amirm
    • Audio Science Review
« Reply #5 on: February 17, 2017, 07:25:42 am »
Consistent for what?
With Power Supplies you want to test them to their rated limit.  If that is 3 amps, then you want to see if it can actually put out that much current.  You work backward from that to determine the dummy load resistance you need.
Offline Brumby
« Reply #6 on: February 17, 2017, 07:34:29 am »
This:
« Reply #7 on: February 17, 2017, 07:48:00 am »
This:
That:
Offline Rick Law
« Reply #8 on: February 17, 2017, 03:50:47 pm »
Another vote for car-bulbs.  Besides being fully capable of dissipating the heat, you have visual confirmation that it is still going and visual reminder that it is HOT.
The only draw back is that their resistance vary.  Well, even a fixed resistor will have varying resistance depending on temperature, but bulbs varies a lot more.
Offline rx8pilot
« Reply #9 on: February 17, 2017, 04:00:55 pm »
Light bulbs have a big inrush current that settles as the element heats up. Some supplies  see that as a problem, even if the supply is working as intended.
Sent from my horrible mobile....
Offline FrankBuss
    • Frank Buss
« Reply #10 on: February 17, 2017, 04:34:19 pm »
I can recommend these resistors, if you need more power:
http://cgi.ebay.de/201054222850
The seller has other values as well. Cheaper than a professional electronics load, if you don't need to test many different ranges. But more expensive than building your own electronics load, which is easy:
Offline innkeeper
« Reply #11 on: February 17, 2017, 06:55:15 pm »
So no a resistance  its not a constant current load....
since voltage is part of the I = E/R
as the voltage increases, to keep a constant current the resistance needs to also increase.
this is a good use of a constant current load... but there not cheap...
so then comes the question... how to load test a supply without one of those fancy smancy constant current loads....
you use different resistor values for different voltage levels that meet your test current requirements.
what are those requirements... the rule of thumb I use is to test within 20% of maximum. (prevents over stressing your transformer, regulator etc)
Here is what I would do personally.
assuming max rating of the 15vac transformer is 1100ma
I would load it to 80% as my max working current (20% safety margin)
so 1100ma * .8  = 880ma max
12v / 880ma = 13.64 ohms.
power = 880ma * 12v  = 10.56w  *  1.2 (saftey margin) = 12.7w
13.64 ohms is a odd value, so id do a little rounding id use nothing lower then 14 ohms  with a min power disputation of 13watt 12 v.
 @12v 14 ohms  13watts
10 ohms @ 10 watts would draw too much current and would be under rated for power dissipation at 12v.
at the low end 1.25v..
1.25v / 880ma = 1.42 ohms
1.25 * 880ma = 1.1watts * 1.2 = 1.32 watts
so at 1.25v
1.42 ohms at a min of 1.32 watts. (id likely round up on the resistance to a value I could easily make up or buy and use a 2watt resistor)
if all you have is a 10 ohm resistor at 10w... and you want to use that to load your supply, then don't exceed lets say 8w (that 20% margin again)
so the max voltage id run to load the supply would be...
8w / 880ma = 9.09v
so lets call it 9V
but your current draw will be much lower then maximum at 1.25v  .... 125ma
if you want an off the shelf resistor you can test though the whole range...
get a 15 ohm 15w resistor (3 series 5ohm 5w resistors will do)
but again the maximum current will be drawn at the highest voltage setting.
It very much depends what your goals are in testing the supply in choosing how your going to load it.
as others have recommended, light bulbs can also be a good cheap load but, be carful there not drawing to much current.
I hope this helps
Hobbyist and a retired engineer and possibly a test equipment addict, though, searching for the equipment to test for that.
The following users thanked this post: raspberrypi
Offline amirm
« Reply #12 on: February 17, 2017, 07:08:40 pm »
Good suggestion.  I have a bunch of these I use for amplifier testing.  They handle a lot of power given their large size.
Offline james_s
« Reply #13 on: February 17, 2017, 07:36:01 pm »
Play around with this http://www.falstad.com/circuit/
You can wire a virtual resistor to a virtual voltage source and experiment with the values and *see* the current flow. If you're a visual thinker it's going to be more clear than plugging numbers into the equations for Ohms law.
Offline FrankBuss
    • Frank Buss
« Reply #14 on: February 17, 2017, 07:52:47 pm »
Or you can use the 10 ohm resistor with 12 V and *smell* the current flow ;D
The following users thanked this post: james_s
Offline rx8pilot
« Reply #15 on: February 17, 2017, 08:11:49 pm »
There is someone out there with a 1% calibrated current nose. They can tell you the current within 1% just before the fire. ;-)
Offline Brumby
« Reply #16 on: February 18, 2017, 12:10:31 am »
For those of us with uncalibrated noses, we can use a FLIR camera.  For those with restricted equipment budgets, a thermocouple probe can give an indication - and for those even more cash strapped, just count the layers of skin removed when you grab it after 1 minute.
The following users thanked this post: nugglix
Offline Gregg
« Reply #17 on: February 19, 2017, 03:09:32 am »
If you are serious about testing your power supply, I have some 500 watt 2.0 ohm open wire resistors that I can send you.  Similar size to these but with thicker resistance wire:
http://www.ebay.com/itm/Cutler-Hammer-G3AP1500-Porcelain-Base-Wirewound-Resistor-15-Ohm-420-W-Lot-of-2-/351949659932
A good source of cheap fixed 12V, 5V, 3V power supplies are old computer power supplies.  They are perfect for the tinkerer that may let some smoke out while on a budget.
PM me if you want the resistors.
Offline Brumby
« Reply #18 on: February 19, 2017, 03:25:55 am »
With 4 of those, it would be just the sort of thing I could use to test a 13.8V 25A power supply I have.
Offline IanB
« Reply #19 on: February 19, 2017, 03:43:21 am »
The trouble with a constant current load is it contains a feedback control loop to vary the resistance to maintain the set current.
If you connect one of these to a regulated power supply, then that power supply also contains a feedback control loop to maintain the set voltage. If you are unlucky the two control loops will fight each other and the whole system will go unstable.
IHMO, it's really not a bad idea to test power supplies with constant resistance loads to avoid such troubles.
Offline Gregg
« Reply #20 on: February 19, 2017, 04:46:02 am »
I forgot to add to my previous post that open nichrome resistors that I  mentioned can be tapped almost anywhere the coils are exposed to vary the resistance.  Most any electric heater that uses nichrome elements that are accessible can be used for load banks with a little ingenuity.
Offline Brumby
« Reply #21 on: February 19, 2017, 05:38:47 am »
I've got a little Nichrome - some..... where.........  ............
Offline boffin
« Reply #22 on: February 19, 2017, 07:02:42 am »
Headlight bulb from a car, 12v, 30-50w.  Find an old sealed beam type as they're fairly robust.
Offline james_s
« Reply #23 on: February 19, 2017, 08:07:18 am »
Headlight bulbs are 55/60W mostly for lowbeam/highbeam. They do make good test loads, although for a LM317 based supply they're going to be too big a load. The regulator is only good for 1.5A.
Offline tautech
« Reply #24 on: February 19, 2017, 08:23:48 am »
Yet perfect for a LM338 based PSU.  :)
Gotta be careful with halogen units though, they'll burn/melt most things they come in contact with.
