I wonder what the fat diode D18 is for.
Does the radio also have a external supply?
What voltage do you measure at the pads now?
Check if there is more than one „grounded“ pin.
There is no extra grounded pins, I specifically measured that. All pins seem to have either a resistance or a P-N level to ground (measured in diode mode with red to ground)
The radio does have an external supply, but that whole secions, with coils and regulators is on a completely different part of the board.
I did not measure current voltages. Not because I did not think of it, but it is a bit hard. Basically, I need to remove several daughterboards (including the one with the power secion) to get this one into few.
Yes, D18 is a typical buck/boost diode, if only I could see a coil connected.....
One hint was 4.1V regulator with on/off.
Maybe it's just a switch.
Not sure I quite follow what you mean here. No one mentioned a 4.1V regulator yet, nor did I see one.
If it is the op-amp I guess it could be just a switch. Or did you find some other 8041 sheet somewhere?
Anyway, I ordered some 8041 boost regulators, unless someone comes up with better suggestions, I'll solder it in and see what happens.
