Do you know of a way to do it - in a standard way - without disconnecting the entire cable? Would disconnecting only GND do it (will try that next if no one answers)?
PS. In case anyone wonders why, it's because I can't change the power bank's model/brand and it doesn't fast-charge itself, if anything else is connected to it.
