Poll
HELP
HELP
3 (33.3%)
HELP
4 (44.4%)
HELP
2 (22.2%)
Total Members Voted: 9
Author Topic: RACAL DANA 9232 DP  (Read 5719 times)
Offline kardaczTopic starter
RACAL DANA 9232 DP
« on: July 11, 2015, 08:37:51 am »
Hello; I have a laboratory power supply RACAL DANA 9232 DP down. At start it shows: FAULT 41 and 42 of the 2 outputs. Someone would he you an idea ?? Or better: there you have the diagram ?? Thanks for your help
Offline Andy Watson
Re: RACAL DANA 9232 DP
« Reply #1 on: July 11, 2015, 08:48:40 am »
Those Racal power supplies are re-badged Thurlby Thandar / TTI units. I believe that model is the equivalent of a Thurlby PL320.
« Reply #2 on: July 11, 2015, 09:05:45 am »
Alas, this model does not match mine, because it is a programmable power supply ..... :'(
Offline Andy Watson
« Reply #3 on: July 11, 2015, 02:41:42 pm »
Thurlby's "PL" range covers many models from manual single output to triple output programmable units.
Offline Psi
« Reply #4 on: July 11, 2015, 03:06:38 pm »
Why does this need a pointless poll?
« Reply #5 on: July 12, 2015, 07:44:41 am »
Hello; I find neither equivalent nor the scheme ...... :-[
Offline miguelvp
« Reply #6 on: July 12, 2015, 01:30:56 pm »
I know you already said that the thurlby PL320 doesn't match yours, but if you want to take a peek look at the PL Series Power Supply pdf in this wayback machine link, since the original site no longer has it or it's gone.
http://web.archive.org/web/20140408212724/http://k1.dyndns.org/Vintage/Sinclair/Other%20Inventions/Other%20Electronics%20Products/
« Reply #7 on: July 12, 2015, 04:01:43 pm »
alas; no schema matching; L-132 not! :-[
Offline Andy Watson
« Reply #8 on: July 12, 2015, 04:20:20 pm »
Could you post a photo?
« Reply #9 on: July 13, 2015, 10:51:24 am »
how to put a picture there ??? :-\ :-\ :-\
Offline Muxr
« Reply #10 on: July 13, 2015, 05:15:38 pm »
I voted on the last HELP that wasn't voted on!  8)
« Reply #11 on: August 16, 2015, 07:56:18 am »
Here image; could someone help me ???
« Reply #12 on: August 16, 2015, 07:59:54 am »
this site is weird; you can not insert a picture !!
« Reply #13 on: August 16, 2015, 08:01:43 am »
Offline miguelvp
« Reply #14 on: August 16, 2015, 08:11:43 am »
@kardacz click under "attachements and other options" when you reply.
The file has to be one of the following extensions: doc, gif, jpg, pdf, png, txt, zip, tar, c, h, hex, bas, xls, odt, asm, wav, aiff, wma, mp3, flac
you can only put up to 25 per post for a maximum total size of 2000KB. and a single file can't be over 1000KB.
Once you are able to attach it, there are ways to make a link to the attached image, but we can get there once you are able to attach the image.
