My DE-5000 came in so I made some tests.
First, I wanted Rs so I pushed LCR Auto until I got Rp and then pushed SER/PAL until I got Rs and measured 6.54 Ohms. This is very similar to what I got on my bench meters. Things are looking good!
Next, I wanted L at 100 Hz so I pushed LCR AUTO until I got Lp and FREQ until I got 100 Ohms. I got a reading of 6 mH and a Q of 0.58. Ls doesn't seem to be an option at this point.
I followed your procedure but I had a different experience.
First, I tried to push LCR Auto until I got R
p. However, R
p never showed up. Only R
s. I have tried several times already.
R
s 1.035 Ohms. (The value is different from the one I got in my first trial.)
Then, I pushed SER/PAL. It changed to R
p. R
p 1.358 Ohms. Again, I got a different value compared with the previous trial.
Next, since I wanted L at 100 Hz as well, I pushed LCR AUTO. I got DCR 0.97 Ohms. Pushing LCR AUTO and pressed FREQ until 100 Hz was shown. This time, I got: Rs 0.97 Ohm. Pressed LCR AUTO twice got: 100 Hz, 3.6 degrees, 0.96 Ohms. Pressed LCR AUTO again, got: APO Q 0.065, Ls = 101uH.
I could not get to L
p by pressing LCR AUTO repeatedly. Each time I saw L
p, it quickly turned to L
s.
To cross check like you did, 2*pi*100*101e-6/1.035 = 0.0613 ~ 0.065 shown under Q on the display.
Ls = 0.065 * 1.035/(2*pi*100) = 1e-4 = 101uH. Checked.
