There's also an older version, the LM2576
HV [datasheet], which operates at 52KHz rather than the 150KHz of the genuine LM2596 series regulators.
Usually the LM2596 series parts are preferable, as the LM2576 needs larger capacitors and inductor, so is more expensive to implement, but for a near novice trying to build a switching regulator on stripboard or other protoboard, the lower switching frequency make it more forgiving of a less than ideal circuit layout.
I have built LM2576 buck regulator circuits using the TO220-5 through hole package on stripboard, and as long as you do the math properly for the design equations in the datasheet 'Application and Implementation' section, choosing the next higher preferred value for the inductor and capacitors, get an inductor that can handle the calculated peak current without saturation, and follow the layout hints in Fig. 8.9 (star grounding and direct connection of the input capacitor and catch diode to the device pins), you can expect it to 'just work'.
Also "LM2576HV" as a search term for prebuilt modules avoids all the 'results noise' due to the fake LM2596 chips!
If you do choose to use a cheap off-brand module, I strongly recommend a crowbar circuit set for 10% overvoltage at the output. Use a heavy duty TRIAC with a surge rating several times that of the fuse (hint: estimate the loop impedance and thus the fusing current and compare I
2t curves) See the TL431 precision reference
datasheet, fig. 30.
