Author Topic: Teflon (PTFE) Tefzel (ETFE) stripping?  (Read 4455 times)
Offline wilfredTopic starter
« on: November 06, 2013, 04:24:45 am »
« Last Edit: August 21, 2018, 08:46:51 am by wilfred »
Offline Kjelt
Re: Teflon (PTFE) Tefzel (ETFE) stripping?
« Reply #1 on: November 06, 2013, 08:43:00 am »
if it is manual stripping and you are sure that it is exactly AWG28 this would be a good wire stripper but even these will from time to time nick the inner wire:
http://uk.farnell.com/ck-tools/t3756-30/wire-stripper-0-30mm/dp/146420
Also read this electrical wire stripper topic, however not within your price it still has some valuable manual stripper tool info in it:
https://www.eevblog.com/forum/beginners/thermal-wire-strippers-are-they-good/msg320220/#msg320220
Offline amyk
« Reply #2 on: November 06, 2013, 10:51:42 am »
Thermal decomposition of fluoropolymers produces some rather nasty chemicals, including hydrofluoric acid.
Offline F4CPY
  • Tune for max smoke
« Reply #3 on: November 06, 2013, 12:39:29 pm »
I often use #28 to #30 AWG wire (strain gages soldering) and mechanical strippers have never done the best job as a heat stripper (for PTFE insulating), but using an aspiration hood (don't know the right term in english!). I heat the strips below 300°C (melting point about 327°c) and only make a gentle mark on the vire.
Some studies (look at wikipedia) said that PTFE starts to decompose near 200°C, so don't breathe the smoke!
If someone have a good trick...
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #4 on: November 06, 2013, 12:56:16 pm »
These look like the ducks guts for what  you are after.  Yeah a little more than what you want to pay but probably your best bet.
Edit: Same tool lower price. picture says Clauss on the handle so it should be same stripper
« Last Edit: November 06, 2013, 01:00:23 pm by robrenz »
