Author Topic: USB Power regulator "stabilizer?"  (Read 3445 times)
Offline ElektroQuarkTopic starter
    • ElektroQuark
« on: November 06, 2013, 07:15:01 am »
Hello:
I'm working in a little project with a microcontroller powered from USB.
As USB power can be from 4.5 to 5.5V (more or less).
Can you suggest a simple buck-boost regulator for 5V?
Any other solution will be welcome.
IƱigo.
« Last Edit: November 06, 2013, 07:36:06 am by EdoNork »
Offline dr_p
Re: USB Power regulartor "stabilizer?"
« Reply #1 on: November 06, 2013, 07:22:05 am »
can't you run the micro at 3.3 from an LDO?
    • ElektroQuark
« Reply #2 on: November 06, 2013, 07:35:37 am »
No, it runs at 5V.
Offline AndyC_772
Re: USB Power regulator "stabilizer?"
« Reply #3 on: November 06, 2013, 07:47:15 am »
What's the specified operating range in the data sheet? It might well work over, say, 4.5 - 5.5V and you don't have a problem.
If you really need a regulator that will deliver a fixed 5.0V output over that input range, I'd look at a SEPIC controller. Head on over to www.linear.com, download LTSPICE, and have fun picking out and simulating a controller IC.
Online mariush
« Reply #4 on: November 06, 2013, 07:47:44 am »
most microcontrollers will work just fine with as low as 4.5v
also in reality rarely the usb voltage will be THAT low. Usually you'll only see as low as 4.7-4.8v due to voltage drop on the wires.
I would just use a very low vdrop linear regulator set to 5v, to simply smooth voltages above 5v. There are Microchip ldos that have 50mV drop or something like that so even if you get 4.8v at the input, the 5v ldo will output about 4.75v which should still be good enough for your microcontroller.
if you really want 5v, use a buck/boost regulator that can work in sepic mode. Higher frequency regulators will require smaller inductors and will work just fine with ceramic capacitors.. see LT1307 or LT1308 for example
(but they're a bit expensive being linear parts)
Offline sleemanj
  • Professional tightwad.
« Reply #5 on: November 06, 2013, 09:58:25 am »
Search eBay for LM2577 Buck-Boost, cost is less than $10 USD, they work well.
    • ElektroQuark
« Reply #6 on: November 06, 2013, 10:25:00 am »
Thank you for all those suggestions.
I will look at them.
