Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Is there a difference between these two Solid State Relays?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Is there a difference between these two Solid State Relays? (Read 1513 times)
dog80
Regular Contributor
on:
November 06, 2013, 10:17:17 am »
Original relay:
http://www.celduc-relais.com/all/pdfcelduc/scfl42100.pdf
Possible replacement:
https://www.relayspec.com/specs/005510/WG_280_D.pdf
These two look similar, but the original has an extra pin that is supposed to be connected to the neutral. What is the purpose of that pin? Can the other SSR be used in place of the original?
EDIT: Fixed link
Last Edit: November 06, 2013, 11:52:12 am by dog80
Logged
Rerouter
Super Contributor
Country:
Question Everything... Except This Statement
Re: Is there a difference between these two Solid State Relays?
Reply #1 on:
November 06, 2013, 11:31:49 am »
the original is a zero crossing style one, I'm going to assume it only switches when active = neutral, where the other one is essentially just a switch,
Logged
dog80
Regular Contributor
Reply #2 on:
November 06, 2013, 11:53:11 am »
I fixed the link for the second relay. It is too a zero crossing type but it doesn't have the Neutral connection
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
