D6 is a name of the component, the pad that came off looks like no contact -- hence the reason it came off.
But really, make some better pics. Don't just photo your screen, take pictures with your microscope camera from both sides and post them here.
Also. Take old connector and new one, and measure things. Stick male part of connector into it and see if it all checks out just like on old one. You gotta make sure it matches. Can't help it using pics online here. Physically remove the new one, compare it to the old one, use continuing mode to check that all contacts are same as on old one.
Post the board in better quality from both sides.
P.S. This looks interesting, but I can't tell what it is from your photos
