so i just got my new ds1054z today and i decided to make a Octopus Curve Tracer and check out some components, and i hooked up a 220mf electrolytic to it and i did see a circle as you would expect to see but i was getting a line above and below it.
i then hooked up another cap to it, and i saw it with just one line above it, and it also had lines running through it.
the lines was intersecting the top of the circle, and bottom. so it was not a separate line.
so are these caps bad? or is it a case of ID10t
and i did test a .1 ceramic cap and saw a nice round circle.
and if you don't know what ID10t is.
http://www.urbandictionary.com/define.php?term=ID10T
