I've made a simple circuit (see attached image) with mosfet IRFZ44N and some part of the LED strip (12V, 0.3A). Both parts I've found when making some orders, so they are not new. The circuit is supposed to control the LED strip (on and off) with a small voltage input. I'm having a problem with running this - the strip is not shining as bright as it does when directly connected to the 12V power source. So, I've added a voltmeter to find out the problem but it only confused me.
![Is my MOSFET broken or my circuit is defective?](https://www.eevblog.com/forum/index.php?action=dlattach;topic=433825.0;attach=2305517;image)
There are two switches - SW1 providing 3.3V input to the transistor gate and SW2 connecting LED strip "-" with transistor drain. So, depending on the switch's position the circuit has four states. I've made voltmeter readings for all of them. Here it is:
SW1: OFF, SW2: OFF, expected: 0V - yes, this is what voltmeter shows
SW1: OFF, SW2: ON, expected: 0V - yes
SW1: ON, SW2: OFF, expected: 12V - yes
SW1: ON, SW2: ON, expected: 12V - ...voltmeter shows 7.5V... and LED strip is barely shining.
Is there anything that I'm doing wrong or the mosfet is partially broken? I'm still a beginner and I do not know where this weird reading 7.5V can come from. Any thoughts?
PS. As a secondary, by the way, question - does my drawing in Kicad meet the standards of such drawings, or will you change/correct something?
Thank you
