Didn't mean to cause confusion with the m-shaped waveform. There's no public documentation for the motor, and it was kind of difficult to match the Hall sensors to the phase windings by measuring line-to-line. I thought it might be easier measuring line-to-neutral, but the motor is Delta-wound and doesn't have a neutral pin. So I created a virtual ground by connecting the Delta motor to a Wye resistor network. I read somewhere that the m-shape is expected, at least for certain motors. But I couldn't find it again, so I added that info in case it's distinctive enough to identify.
