Author Topic: Is it safe to stick my multimeter probes in the wall socket ?  (Read 48689 times)
Offline madires
  • A qualified hobbyist ;)
Re: Is it safe to stick my multimeter probes in the wall socket ?
« Reply #50 on: November 17, 2012, 12:12:24 pm »
I once accidentally touched a fully charged photoflash capacitor (330uF@380V). That will teach you some respect. My whole arm hurt for two days.
Ouch!
Offline ptricks
« Reply #51 on: November 18, 2012, 12:45:21 pm »
I have done that too. Was taking apart a digital camera and the cap voltage ran through a circuit board far away from the cap, touched it and damn that hurt  :o
Offline G7PSK
  • It is hot until proved not.
« Reply #52 on: November 18, 2012, 09:13:31 pm »
I once got a 10K jolt from an electric fence that did no hurt as much as the landing on top of the metal gate. I was opening a metal gate while sitting on a horse and baked the hose into the electric cattle fence, I got zapped the horse got zapped and jumped forward about ten feet and upwards to boot so I got launched and landed on the gate one leg each side.
Offline M. András
  • Country: hu
« Reply #53 on: November 19, 2012, 07:19:57 pm »
I get the impression that some people on here are scared shitless by the mains. As long as reasonable precautions are taken there is no reason to be scared of a few hundred volts in a system nor of high amps for that matter. The highest amperage that I have worked with is ten thousand, quite interesting as when switched the field in the conductor would make 200 KG of steel jump.
i can imagine the fences and blast proof walls around each socket in their house and the long ceramic rod which they use to plug in the plugs >:D
