you can use incandescent lamp, but it's resistance is very dependent on lamp temperature and it's temperature highly dependent on a feeded power. So, if dummy load with variable resistance is ok, you can use it.
Also note that incandescent lamp has inductance and is not good for using as RF dummy load, especially on SW, VHF and higher.
LED lamps has semiconductors inside and will be very bad reactive load with non linear properties
