From a purely electrical standpoint, the dryer/stove receptacles have the correct voltage to run a 220 volt device. But, from a practical standpoint, you should have a properly wired 15 or 20 amp branch circuit with proper type receptacle. A dryer receptacle is usually overcurrent protected at 30 amps and a stove receptacle can be 60 amps! A fault in your station wiring and you would have a fire in moments. The best option, if you bought the 220v station, would be a 110v to 220v step-up transformer. It would have the proper fusing and energy levels for your application.
And on a different front, that is not a particularly good price for that station. It is available under several brand names for less. For example, MCM Electronics in Ohio, sells their Tenma brand exact same version of this unit for $99.99 USD. Catalog #21-11410.
Best of luck, and be careful!
