There is no right answer until you take apart the new power supply.
The biggest concern is that an actual power supply with several tens of amps will not forgive any of your mistakes and will turn allmost all tiny electronics parts into fuses. Also, there are some complications with ground loops.
Still, that new PS can be worse. Rating and certifications are not in vain, but chinese one are not the same with european and american ones.
