I need a quick and dirty way to detect the presence of a small black matte object, using Arduino
I want to try using a IR LED like this:
and the corresponding receiver:
The object moves along a fixed track. At the location of interest, I plan to orient the two LEDs (tx/rx) facing each other, and if the object blocks the IR ray, the Arduino would get the signal.
The challenge is that the object is small (2mm diameter). It's too small to block all the IR light. To better "focus" the IR beam, I want to build a conical opaque "cover" to the transmitting LED with a tiny 1mm or so opening so that the object can fully block the IR ray. Is this a good approach?
Thanks
