Hey all,
I am building a PCB that will sit inbetween an existing devices interface. The device in question is the Vappeby Gen3 Bluetooth speaker from Ikea. The UI seems to be straight forward, a couple of inputs on the MCU, with the appropiate pull-ups/downs, and 2 LED's, sitting on a ribbon cabled PCB.
I haven't traced out the specifics perfectly (working with fotos), but I was a bit too eager in my schematic I suppose. I am putting an ESP dev board in between the ribbon cable. So for the out-side of my PCB, e.g. the LED outputs, the button inputs, I don't have to do much/anything, as all the inputs etc are being taken care of. But I now wonder, between the two MCU's, is there anything needed? Both are 3v3, so no level shifting is needed, but some 22Ohms in-line? Pull-ups/downs? Or are the internal's MCU pull up/downs enough? What about when I configure the pin as an output, and let (i have no idea what the actual value is) drive the pin with 20mA? Won't that be too much for the receiver? Obviously I don't have a spec sheet, but ballparking things propably helps a bunch here.
