Unless you get a very expensive temperature-controlled soldering station, you won't be able to control (or even see) the temperature anyways.
If you do, 350C is probably enough for leaded solder. I like to go 420C for lead-free. But that's at the school's lab (with expensive soldering stations).
At home I just use a 25W. No idea how hot it gets, but it's fairly standard.
