Thanks for the explanation. I did understand the basics of what's happening in the very high impedance meters.
However I still don't get how protection + high impedance is provided in case of sudden jumps (input is at 0v, then suddenly it jumps to 200V). Eventually the input amplifier will raise it's power supplies to 200v, but in the meantime, what is providing the protection ? I'm assuming that at least 10M input impedance is maintained during the ramp-up period. I guess I will have to look in detail at the schematics.
Or if someone could give me a schematic of 10M input impedance + protection for an ADC ( without bootstrapped power supply ), I would very much appreciate it. Or is 10M input impedance only possible with bootstrapped power supply ?
Yes, you are correct, sudden jumps don't see the same input impedance. As you say, the bootstrap supply takes a finite time to track. At that point you are down to the input
series resistance of the input circuit (88k in the Datron case) and the protection components. There will always be parasitic capacitances too forming low pass filters. The >10G ohm input resistance applies to reasonably steady state measurement, there is the question of when a sudden large step voltage becomes an input protection event. Note that the input resistance is >10G, not 10G ohm, ie. there is no 10G ohm resistor defining the input resistance - the input resistance is made up leakage, input bias currents etc, so the spec will be the 'guaranteed' minimum, not a fixed value.
In your second paragraph you seem to have switched from 10G to 10M, from what you've said before I assume this is a typo. If you really want a simple 10G ohm input without going to the trouble of bootstrapped and isolated supplies, then you could try just using a 10G ohm input voltage divider. Use a high quality, high voltage 10G ohm series resistor (yes, you can get them) together with a 10.01M shunt resistor. This would give you 1mV per Volt output with a 10G Ohm input resistance. Obviously there are drawbacks with this scheme...
- It is likely to be a bit noisy, both from resistor noise and pickup. Careful assembly and screening would help.
- Temperature stability and tracking of such high value resistors will probably not be good, limiting your accuracy.
- Stray capacitances would make this a DC only measurement solution, unless you add a parallel capacitive divider.
- You would need to buffer the output with a low drift, Very low Ib, low Vos opamp, but that is doable.
- You then need to scale the voltage to your ADC range, not too bad for 100mV at 100V, doesn't need very much gain but 1mV at 1V (or lower) will be more troublesome.
As I say, if you want the 'simplest' way of getting your 10G Ohm input resistance, this will do it. On the upside it would need little or no input protection, dependent only on the maximum voltage rating of the 10G Ohm resistor.
