Author Topic: Input Impedence  (Read 1138 times)
Offline jj5Topic starter
  • Still learning about electronics...
    • In The Lab With Jay Jay
Input Impedence
« on: February 24, 2023, 09:45:55 pm »
The manual for my scope says that its input impedance is 1 MΩ. I hooked channel 1 on my scope
up to my digital multimeter
and the measured resistance was 0.7767 MΩ.
Does that mean that the other 0.2233 MΩ is reactance?
Online bdunham7
Re: Input Impedence
« Reply #1 on: February 24, 2023, 10:14:34 pm »
Hmmm, no, the 1M should be the DC resistance.  Can you try changing the vertical scale for CH1 to at least 5V/div?
The following users thanked this post: jj5
Online Bud
Re: Input Impedence
« Reply #2 on: February 24, 2023, 10:18:57 pm »
One Chinese made gizmo is measured using another Cinese made gizmo. Nothing can go wrong.
You should start with checking accuracy of your Owon.
Re: Input Impedence
« Reply #3 on: February 24, 2023, 10:23:54 pm »
Ah, so the problem seems to be that the BNC to banana adapter that I was using had a 1.5 MΩ resistance across it. I used a different cable (BNC to banana) and the measured resistance is now 1 MΩ as expected. Thanks. :)
« Last Edit: February 24, 2023, 10:28:06 pm by jj5 »
Offline shapirus
  • Country: ua
Re: Input Impedence
« Reply #4 on: February 24, 2023, 10:33:31 pm »
these chinese gizmos tend to be surprisingly accurate and rarely the place to start troubleshooting at these days.
Offline BillyO
Re: Input Impedence
« Reply #5 on: February 25, 2023, 12:13:46 am »
Indeed.
I have two trombones here, both from China.  One is $200 and is what you'd expect.  The other is $6000 and is a full out professional instrument of the finest quality.  Seems painting everything from China with the same brush is a little silly.
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
The following users thanked this post: David Aurora, newbrain
Online coppercone2
Re: Input Impedence
« Reply #6 on: February 25, 2023, 12:26:53 am »
that adapter is shit and you should throw it away. You can try cleaning it but be careful dipping those in iso, I had them warp from even 50% iso dip.
I just measured 3, one from 1950 or 60, and 2 from the last 10 years. They all read open circuit.
SO it does seem like a chinese gizmo was the problem... at least I feel better for buying pomona from a supplier .
« Last Edit: February 25, 2023, 12:33:25 am by coppercone2 »
Re: Input Impedence
« Reply #7 on: February 25, 2023, 12:30:26 am »
Yeah, I binned it.
The following users thanked this post: coppercone2
Re: Input Impedence
« Reply #8 on: February 25, 2023, 12:49:31 am »
For those bringing China into it, let's not forget How it Works.
The following users thanked this post: David Aurora, newbrain, DavidKo
Online BeBuLamar
Re: Input Impedence
« Reply #9 on: February 25, 2023, 08:48:15 pm »
Indeed.
Yes I agree with you. Chinese made products ranging from the best to the worst so a Chinese made gizmo doesn't mean anything.
