As aeberbach says, material cost is not too high, about 30c per drawer, $1.20 per box, so close to $3 for each "set". You can download Cura and it will calculate for you.
The bigger issue is having a machine with enough build area and speed. These are not too big, so most can do that, but speed wise my machine estimates ~16hr print time. Could cut it to 8hrs with thicker layers.
