Author Topic: Info about RF VOLTMETER  (Read 4945 times)
Offline lionTopic starter
« on: October 11, 2016, 09:57:16 pm »
Hello everyone.
I've searched everywhere but I cannot find too much info about RF VOLTMETER. Can anyone link me or explain me how it works? This is my last resource.
 |O
Offline barry14
Re: Info about RF VOLTMETER
« Reply #1 on: October 11, 2016, 11:53:17 pm »
Assuming that RF stands for the usual (Radio Frequency), an RF Voltmeter is a piece of electrical test equipment designed to measure the voltage of electrical signals whose frequencies are in the radio frequency range (usually considered to be anything above about 1 MHz.  The frequency coverage of any one such Voltmeter can vary considerably depending on the application.  If you are interested mainly in AM broadcast radios, for example, then a meter covering 0.5 to 2 MHz is probably sufficient.  For FM broadcasts, the range would have to be increased to at least 110 MHz.  For WIFI and other digital radios, the range would again have to be increased to several GHz.  Most RF Voltmeters have an input impedance of 50 ohms since that matches the impedance of RF transmission lines and is a widely used impedance level in high frequency circuits.  The input level range again will vary with the application but can range from microvolts to volts, with the former for measurements on receivers and the latter more for measurements on signal generators and low power transmitters. RF Voltmeters are manufactured by many companies including Agilent.  Just google RF Voltmeter for more information or,if you  provide a more specific question, I will expand this response.
The following users thanked this post: lion
Offline Len
« Reply #2 on: October 12, 2016, 12:10:45 am »
Here's a couple of pages about measuring RF voltages using a regular voltmeter and a special probe circuit:
http://n5ese.com/rfprobe1.htm
http://www.techlib.com/files/detect.pdf
DIY Eurorack Synth: https://lenp.net/synth/
