Author Topic: ICL8038BC what to do with it?  (Read 2014 times)
Offline carbon dude oxideTopic starter
« on: April 02, 2013, 08:22:27 pm »
hello, i have been tidying my bench today and sorting out my component draws (monster task as it has a tonne of random components in that need sorting) and i came across a ICL8038BC from RS (306-314) and i noticed that it was a waveform generator.
is this chip any good? if so how would i use it to make my own waveform generator?
Everything Should Be Made as Simple as Possible, But Not Simpler
Online mariush
Re: ICL8038BC what to do with it?
« Reply #1 on: April 02, 2013, 08:40:08 pm »
Have you thought of searching Google for the datasheet using the IC name?
Here, found it between the first few results:
http://www.intersil.com/content/dam/Intersil/documents/fn28/fn2864.pdf
The datasheets explains how it works and has a few circuit examples you could use.
« Reply #2 on: April 03, 2013, 04:25:32 pm »
Just remember that that IC runs pretty hot, a stick on heatsink will not go amiss.
Offline Tepe
« Reply #3 on: April 03, 2013, 05:32:39 pm »
The very same RS supplies the data sheet:
http://docs-europe.electrocomponents.com/webdocs/0118/0900766b8011862a.pdf
as well as some extra information
http://docs-europe.electrocomponents.com/webdocs/001b/0900766b8001b696.pdf
