Author Topic: Inductor proximity effects?  (Read 1001 times)
Offline TheDoodTopic starter
« on: December 06, 2019, 12:15:45 pm »
I'd suggest you repost your inductor question as a new topic with a more appropriate title e.g. "Inductor proximity effects?"
It was pointed out I start a new thread, thanks Ian, feel free to drop your any of your inductor knowledge here.
What are some basic guidelines to inductor spacing and/or orientation? Is there some sort of linear relationship between (A/mH) & the proximity in which you can place other inductors or other magnetically influenced components? How close can capacitors be placed? What types of generic design limitations (utilizing inductors) should I keep an eye out for?
If I've 2 identical inductors, both common mode choke types with the core standing/mounted perpendicular to the PCB, can I increase the total inductance over using a single standalone choke, if I placed them side by side within close proximity to each other, in such a way that that their cores' flux direction mirrors each others, to the point that if the cores were fused together that the mag flux would be doubled rather than cancelled? What effect would this orientation have?
Online Zero999
  • 0999
Re: Inductor proximity effects?
« Reply #1 on: December 07, 2019, 05:10:26 pm »
The coils have to be directly facing one another to ensure good coupling. If they're at 60 degrees, then there will hardly be any coupling. How the inductor is wound depends on how far the field extends. A toroidal inductor hardly leaks any flux, but a large pancake shaped inductor is much more leaky.
The following users thanked this post: TheDood
Offline Neilm
« Reply #2 on: December 07, 2019, 07:20:11 pm »
Some inductors are shielded so leak very little flux, others are open frame and can have some interesting issues (I did once have one of these couple to a power plane that really hit the efficiency). Could you post a few more details or a link to the original discussion so I could get some background?
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
« Reply #3 on: December 07, 2019, 08:37:47 pm »
Thanks guys,
I was trying to assess the effect on a rectified AC capacitive dropper waveform after flowing it through 2 identical common mode chokes wired in parallel.  Both with an individually lower current rating than the total cct current being flowed, though in parallel within their rated specs. I was trying to determine how proximity and orientation would effect the intended output waveform. I was hoping that I could orient in a position in such a way that the field lines wouldn't cancel, but compound (if anything), but I've read that inductors in parallel reduce total inductance, so I'm just not sure I'm comprehending (it seems the equation doesn't have any variables for proximity or orientation, the things I thought would have the greatest impact on inductance). I figured if I could determine the most favorable positions and/or why, that I'd be able to then orient inversely for a minimal interaction.
When I simulate inductors in parallel in LTspice, it seems the program accounts for proximity. The closer I place the parallel inductors to each other, the less filtering I notice. I've run some simulations and used 100mH as my inductor size, but I've only 0.35A rated inductors and the cct sim was for 0.5A, so thus what sparked my question.
Also, I'm curious about EMI? If I were designing an RC car or drone, what kind of shielding or proximity to antennas ect should I be aware of? If the Hz of the waveform going into the inductor is different than the radio frequency used for wireless commands, I shouldn't have interaction, or should I? What signals are most susceptible to inductor noise, or maybe there isn't a generic correlation to be had? Can you wrap an inductor in aluminium foil and mitigate EMI? Will inductors induce a charge inside capacitors if placed within close proximity?
EDIT:
Link to original thread...
https://www.eevblog.com/forum/beginners/bypassing-loads-under-constant-current-efficiently/
« Last Edit: December 08, 2019, 11:46:23 am by TheDood »
Offline radiolistener
  • Country: ua
« Reply #4 on: December 08, 2019, 11:05:10 pm »
In order to reduce coupling between two inductors, you're needs to place them at 90 degree to each other.
In order to reduce parasitic resonances of inductor, the coil turns should be evenly distributed along the length.
The best parameters can be achieved when coil diameter is equals to the coil length.
Use wire from high purity copper with no chemical additives to get better Q-factor.
Use low loss RF isolators for the coil frame.
« Last Edit: December 08, 2019, 11:13:32 pm by radiolistener »
