Hello, I have a question about INA 326 instrumentation amplifier and pressure transducer. I use a circuit from INA326 datasheet 9 page, except I don't use filtering at output of amplifier. R1=4,7k, R2=100k, so gain could be aproximetely 40-50. On the pin 5, I connect 100k resistor and 0,1uF condensator. Problem is that, when I apply pressure to my transducer voltage between data signals is 30mV. So, for my gain, output voltage could be about 1,2-1,4V, but when i check voltage with multimeter I see only 160mV, and when I applied more pressure to my transducer, voltage in the output of amplifier didnt change, still 160mV. Both, transducer and amplifier powered by Arduino, and I check voltage between amplifier output pin and common ground in the breadboard. What can be problem? I attach INA326 datasheet and my breadboard connected circuit, maybe there are some connection errors.
http://www.ti.com/lit/ds/symlink/ina326.pdf
