Many semi's are not realistic when operated at datasheet headlines. Datasheet hype varies with every semi manufacturer. You have to read between the lines.
Does it output 3A in higher ambient temperatures, on 1oz copper?
Read the fine print: SOIC8E 50°C/W on a JESD51-7, 4-layer board.
And why are they suggesting B340A Schottky rectifier diode, when that little SMA is going to cook and die, after it burns your finger. Do the math on how hot it will get, it can't do steady 3A either.
I think MP has close ties to Asia and I know to be very careful perusing such a datasheet which is not trustworthy.
